Puff
May 21, 2021Follower
Connect to another Computer.
My other computer claims there is no connection, even though the router works for all other things in the h ouse. I used to have Lynxis and that had a little plastic piece that I had to connect to the other computer to pick up the signal from the main computer and router.. Is there some similar piece of equipment I need to hook up to that computer that would work with Netgear? Sorry but I am very unfamiliar with all these things. Thanks!
- microchip8Master
how are you connecting? wired or wireless?
which firmware version are you using?
> My other computer [...]
The non-psychics in your audience might know nothing about any of
your computers, but especially not about your (unspecified) "My other
computer".> [...] I used to have Lynxis [...]
Some Linksys router or other, or something else?
> [...] and that had a little plastic piece that I had to connect to the
> [...]The non-psychics in your audience might know nothing about any
"little plastic piece", either.If that "little plastic piece" was a USB-wireless adapter, then you
should be able to use it with your Netgear router, too. (Unless you
threw it away when got your new router.) Most likely, it was not
something that "that [router?] had", any more than "that [router?] had"
any of your computers.> [...] Is there some similar piece of equipment I need to hook up to
> that computer that would work with Netgear? [...]Keep using the same one (whatever it is)?
> [...] Sorry but I am very unfamiliar with all these things. [...]You might need to get more familiar with them than "little plastic
piece". The non-psychics in your audience can't see it, and if no one
knows what it is, then progress might be difficult.- shreyakithAspirantFast wifi performance: Get up to 2000 square feet wireless coverage with AC2300 speed (Dual band up to 600 + 1625 Mbps). Recommended for up to 35 devices: Reliably stream videos, play games, surf the internet, and connect smart home devices.Be ready to turn your house into a Wi-Fi zone with this Netgear Nighthawk R7000P AC2300 Smart MU-MIMO Dual-Band Gigabit Wi-Fi Router. It can amplify the speed up to 1625+600mbps. Powered by the 1GHz dual-core processor, it promises better video streaming, lag-free gaming, surfing and so on. Through parental controls, it limits daily internet time for websites, apps and more. You can further prioritize network traffic by application and device with its dynamic QoS. It is compatible with Amazon Echo and Alexa that let you control it with voice commands.External antennas for improved WiFi coverageSimultaneous streaming of data to multiple devicesDynamic QoS prioritizes network traffic by application & deviceHigh powered amplifiers & antennas help extend WiFi coverage throughout large homes & even backyards
