trx-4-defender
Nov 30, 2019Aspirant
connect to caomcast ( xfinity) modem
I just install Nighthawk R8000 to Xfinity modem. - work for couple hours, - still have 2,4G from comcast - R8000 give me one 5Ghz band Install nighthawk app and stuck at login to 2.4Ghz Then no...
- Dec 01, 2019
your Netgear "modem" is not a modem but a router. Your ISP provided device is a modem/router combo. Connecting these two together without setting your ISP modem/router into bridge mode creates a double NAT which you should avoid
The firmware version of the R8000 can be found either in the app or the Web GUI at http://192.168.1.1
Your ISP modem/router most likely has a label on it with the device model
microchip8
Nov 30, 2019Master
You're running 2 routers and creating a double NAT. Set your ISP modem/router to bridge mode if possible and use the R8000 as the router. Also, it would be useful to know the ISP modem model and firmware version on the R8000
- trx-4-defenderNov 30, 2019Aspirant
Thanks for your respond,
I need of a procedure of how to setup,
When I set up, it just went very fast and smooth untill I see only one band which is 5Ghz,
I then down load the nighthawk app then I was be able to see other 2 bands
But then I would lost the internet connection, so I unplug the ethernet cable from the comcast modem and go back to the original setup of comcast, which is their modem/router.
I don't know where to get the info of firmware, my netgear modem is R8000, ac3200 X6
Thanks
- microchip8Dec 01, 2019Master
- trx-4-defenderDec 01, 2019Aspirant
I am having hard time to re-connect to http://192.168.0.1 or http://192.168.1.1
Now I understand the double NAT, I will looking for how to disable the ISP Modem/router then re-connect my NETGEAR R8000 to and set up again
Another question, now when you disable the 'bridge' from comcast modem/router.. can I switch back if the NETGEAR router set up do not go through?
Thank you
