trx-4-defender
Nov 30, 2019Aspirant
connect to caomcast ( xfinity) modem
I just install Nighthawk R8000 to Xfinity modem. - work for couple hours, - still have 2,4G from comcast - R8000 give me one 5Ghz band Install nighthawk app and stuck at login to 2.4Ghz Then no...
- Dec 01, 2019
your Netgear "modem" is not a modem but a router. Your ISP provided device is a modem/router combo. Connecting these two together without setting your ISP modem/router into bridge mode creates a double NAT which you should avoid
The firmware version of the R8000 can be found either in the app or the Web GUI at http://192.168.1.1
Your ISP modem/router most likely has a label on it with the device model
trx-4-defender
Thanks for your respond,
I need of a procedure of how to setup,
When I set up, it just went very fast and smooth untill I see only one band which is 5Ghz,
I then down load the nighthawk app then I was be able to see other 2 bands
But then I would lost the internet connection, so I unplug the ethernet cable from the comcast modem and go back to the original setup of comcast, which is their modem/router.
I don't know where to get the info of firmware, my netgear modem is R8000, ac3200 X6
Thanks
microchip8
Dec 01, 2019Master
- trx-4-defenderDec 01, 2019Aspirant
I am having hard time to re-connect to http://192.168.0.1 or http://192.168.1.1
Now I understand the double NAT, I will looking for how to disable the ISP Modem/router then re-connect my NETGEAR R8000 to and set up again
Another question, now when you disable the 'bridge' from comcast modem/router.. can I switch back if the NETGEAR router set up do not go through?
Thank you
- microchip8Dec 01, 2019Master
You should be able to switch back the mode on your ISP modem/router
NETGEAR firmware automatically sets 10.0.0.1 as LAN address if it detects another router is connected to your network, like the ISP device you have. You may try login to http://10.0.0.1
Thank you so much Microchip8,
I will try again, but this time I will disable the comcast modem/router's 'bridge' before reinstall the netgear R8000.
I will let you know how it goes.
Have a happy holliday!
