cleveland35
Jul 30, 2020Aspirant
Connect wireless laptop to ethernet printer
I have an HP Officejet 6700 connected with an ethernet cord to my network. Printing is fine from a desktop or laptop when using a wired connection to the router. When I use the laptop in "wireless"...
- Aug 06, 2020
> I had already updated the firmware [...]
How could I have not known that?
> I don't know what "Did you use Address Reservation on the router to
> ensure that that's always true?" means. [...]If the IP address of the printer changes, then your computer might
not be able to find it where it was expected to be.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Manage
Reserved LAN IP Addresses". If you reserve an address for your printer,
then it should always get the same address, which might help in a
situation where it had been wandering. No guarantee, but it's an easy
(and generally harmless) experiment to run.
cleveland35
Router:
Hardware Version R7000P
Firmware Version V1.3.1.64_10.1.36
Connected to a cable modem.
No problems using the desktop or laptop when using an ethernet wired connection.
Both running Win 10.
Not using "guest" networks.
Just trying to use Windows to add the printer. Doing START and then type printer, then select Printers & Scanners and doing Add a Printer.
The laptop that was wired saw the printer, allowed it to be added and could print.
All devices appear in the router list. The printer is 192.168.1.8
Have a conflict but will try to ping the devices tomorrow.
Thank you for the quick attention.
antinode
Jul 30, 2020Guru
> [...] will try to ping the devices tomorrow.
Ok. Could be educational.
Another diagnostic would be to use a web browser to try to talk to
the printer's "embedded web server (EWS)" at
"http://<printer's_LAN_IP_address>". "ping" uses an ICMP echo request,
which is a low-level IP network thing. Access to the EWS might more
closely resemble normal printer (TCP/UDP) traffic, making that a more
realistic test.
Conceivably "ping" could work, but the firewall-like rules used for
guest isolation, if misapplied (by lame firmware), might still block
normal wired-wireless traffic.
That looks a little stale.
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and, especially
for a topic like "Manually Upload Firmware to the Router".)
- cleveland35Aug 06, 2020Aspirant
Sorry it has taken so long to get back, particularly after you responded so quickly.
I think I am going to forget about printing wireless from a laptop after continued strangeness when printing when connected by ethernet. Here is an example:
Print from Excel. It thinks the printer is offline when in fact it is not. Wait a while and still no print. Go into "Printers & Scanners", select the printer and select Manage. Then run the troubleshooter. It runs, claims it does not find any issues, and then the printer starts running and I get what I sent.
This is consistent and repeatable. If I print again, I have to do the same steps. It appears that the output will not appear unless I run the troubleshooter. And the troubleshooter claims it can't find anything to fix.
- antinodeAug 06, 2020Guru
> [...] And the troubleshooter claims it can't find anything to fix.
Could be lame router firmware.
> That looks a little stale.Still true.
> [...] The printer is 192.168.1.8
Did you use Address Reservation on the router to ensure that that's
always true?- cleveland35Aug 06, 2020Aspirant
I had already updated the firmware before the most recent printing. It is currently:
Firmware Version V1.3.2.124_10.1.64
I don't know what "Did you use Address Reservation on the router to ensure that that's
always true?" means. What would I need to check or do?Thank you...
