sgjourney
Nov 02, 2021Aspirant
connected devices
Can I direct specific devices to desired radio channels(2.4ghz or 5ghz)? Why does a device show connected to the router when it has been dead for weeks?
sgjourney
btw i have a Nighthawk X6 R8000
Nov 02, 2021Guru - Experienced User
If you're using smart connect, devices can switch between the 2 bands.
If you're wanting devices on certain bands, you can disable smart connect and choose which to connect to.
Not sure what you mean about a device being dead for weeks. a little more detail might help on that one
