racerfern's avatar
Jun 09, 2017
Connected, no internet
I just bought a Netgear R7800 and updated to the latest firmware v1.0.2.28. I have optimum cable service and a wifi issue with android devices. I also have a win10 tablet that initially says "connect...
  • netwrks's avatar
    netwrks
    Jun 26, 2017
    I meant the modem.. Two parts - modem and router.. When you add a new router to a network, you start by turning off the modem to flush the old MAC address of the older router out of the MAC table. Once it has been off for about 5-10 minutes, power up modem (wait for the modem to come back online), then, power up router (properly cabled up to modem) then configure router when it is online. If your ISP does not release the MAC address of you old router, you can reconfigure your new router with the old router's MAC address, or a laptop MAC address, if you were successful connecting to the Internet after removing your old router. Clear as mud?
