colbyldickerson
May 07, 2024Aspirant
Connected to router, but no internet
I have a AC2000 WiFi Router (R6850) . We had no problem with the router beforehand but around 4 days ago we had medium rain fall and our internet went out during it, however, it is still out but is f...
May 07, 2024Guru - Experienced User
Is the Internet LED on top of the router AMBER by chance?
Sounds like the ISP services are not working up to the router.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Make contact with the ISP to secure there services are good up to the modem and router.
colbyldickerson
- No, the power button is solid green and the third light is green and blinking.
- We don't have a modem, we have the Ubiquiti power box and the router itself.
- We have powered it off many times and turned it back on and unplugged it from the power strip and wall it's connected to but nothing has worked, I haven't kept it powered off for 1 minute but I can when I'm home.
- FURRYe38May 07, 2024Guru - Experienced User
Connect up a wired PC or laptop to this power box and check as well. If you don't get any thing here, then the ISP needs to check into this.
- colbyldickersonMay 07, 2024Aspirant
I'll try this when I'm home thank you.
