netoperator
Oct 07, 2024Aspirant
Connected without internet
I have AC 4000 Nighthawk X65 model number R8000P. On my phone it indicates that I am connected without internet. How do I correct this ? Thank you
Oct 08, 2024Guru - Experienced User
Did something change so you're getting this?
Is this a new install?
Any other devices having issues?
What modem/gateway is the router connected to?
- netoperatorOct 08, 2024Aspirant
Nothing has changed because this is clean install on a new machine. No other devices has any issues. I use Verizon jet pack. The phone is a Samsung with Verizon software. I have Windows 11 and I update the machine every morining. Likewise I get upadates as soon as available. Thank you.
- FURRYe38Oct 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
