corvairbob
Mar 10, 2021Tutor
connecting 2 units together
i have the c7000 combo unit and i just got the linksys ea7500 router. what i would like to do is put my camera system on the linksys unit to try to get it a bit harder for hackers to get to and then ...
corvairbob
Mar 10, 2021Tutor
thanks i have the ethernet cables connected as that youtube shows now. the only thing i did not do was connect it in that bridge mode. when i was setting it up all those pages did not show up when i was installing it, it kept telling me to press the reset button and wait. so i waited like hours. i had to keep the pc connected via that cable the whole time and i see that was how to do that.
at this time i have it set so i see both routers on my phone. and i can connect to either one out in the back yard at the same strenght on my phone but they are about 4' apart at this time down stairs. also if i connect thru wifi onmy pc i can get into the settings on the linksys router. i expect when i change that to bridge mode i will not be able to get into the linksys settings anymore unless i reset it.
so tell me this if you can if i put it into bridge mode will my stregnth be more because the ls will be higher in the air?
or will it be so all i see is the netgear router?
or will i still see both and have about teh same range no matter what unit i connect to?
so the way it is set now will i gain anything?
thanks.
antinode
Mar 10, 2021Guru
> [...] i have the ethernet cables connected as that youtube shows now.
_Which_ "that youtube"? And that is how, exactly? And how does that
compare with what the product documentation says?
> [...] the only thing i did not do was connect it in that bridge mode.
_Which_ "it" is that? What, exactly, does "that bridge mode" mean to
you? "Bridge mode" is a widely misused/misunderstood term. Does
"bridge mode" mean to you what it does to Netgear or what it does to
Linksys?
https://www.linksys.com/us/support-article?articleNum=247436
Note "Bridge Mode" versus "Wireless Bridge". Obviously different,
but both "Bridge" modes. Netgear's terminology is less ambiguous.
> [...] if i connect thru wifi onmy pc i can get into the settings on
> the linksys router. [...]
_How_, exactly can you do that?
> at this time i have it set so i see both routers on my phone. [...]
"see"? Are you talking about their wireless SSIDs, or what?
> [...] i expect when i change that to bridge mode i will not be able
Why not? If you know its (LAN) IP address, then I'd expect
specifying that in a web browser to work.
> [...] if i put it into bridge mode will my stregnth be more because
Huh? "the ls"? Does that mean the EA7500?
Tell me this, if you can: How would changing the operating mode of
the EA7500 change its elevation?
You seem to assume that someone who reads this scrambled mess would
have some idea of how "it is set now", whatever "it" is. I sure
wouldn't bet on it.
If you have two routers, and both are configured as full-function
routers, then I'd expect problems with access from the outside world to
devices which are connected to the inner router. Which is why you keep
getting suggestions to configure the EA7500 as a WAP (which Linksys
calls "Bridge Mode").
Have you looked at the IP addresses of your devices when they're
connected to the C7000 versus when they're connected to the EA7500?
