pjdavies
Apr 27, 2022Aspirant
Connecting a DECT phone to the Nighthawk R8000P?
Hi there Can the R8000P support a DECT basestation and VOIP? I have a Siemens Gigaset S400A phone and looking to transfer my BT line to VOIP?.. Can I use one of the LAN ports to connect the base...
Apr 27, 2022Guru - Experienced User
Something to check with the phone mfr about regarding there product.
If it's got a RJ45 LAN port, possible it could be connected. All depend on what the phone needs for services thru a router.
