Shotzy
Oct 14, 2023Follower
connecting a hard drive to router (mine is AC1900)
Hi. I'm a bit technologically challenged. Can someone give me a brief step-by-step description of how to connect a hard drive to my router. The router has this functionality. I need to format the dri...
Oct 15, 2023Guru - Experienced User
Not using exFAT.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-ReadySHARE-on-my-NETGEAR-router
With what you'd like, why not look at a NAS?
They can be picked up used pretty cheap.
You'll get better functionality versus trying to cobble something together.
Plus you can add a 2nd drive for redundancy.
- microchip8Oct 15, 2023MasterIn addition to the above, password protected drives are not supported by any consumer router, NG or otherwise.
