teriley4492's avatar
teriley4492
Connecting a printer via ethernet on AC1900
When I connect my SG800 printer (used for dye sublimation) to any of the ethernet ports I get an amber light and the printer reports an IP address of 192.168.000.200. However, when I ping that addres...
  • michaelkenward's avatar
    Aug 11, 2017
    teriley4492 wrote:
    ...the printer reports an IP address of 192.168.000.200.
    Doesn't look like a valid IP address.
    What address does the R7000 report for itself?
    The default would be http://192.168.1.1
    An amber light on a LAN link or Ethernet port is usually a sign that it is operating at 100 Mbps. See page 12 of the manual:
    >>>> R7000 | Product | Support | NETGEAR <<<<
    It does suggest that you have a connection.
