teriley4492
Aug 11, 2017Aspirant
Connecting a printer via ethernet on AC1900
When I connect my SG800 printer (used for dye sublimation) to any of the ethernet ports I get an amber light and the printer reports an IP address of 192.168.000.200. However, when I ping that addres...
- Aug 11, 2017
teriley4492 wrote:...the printer reports an IP address of 192.168.000.200.
Doesn't look like a valid IP address.
What address does the R7000 report for itself?
The default would be http://192.168.1.1
An amber light on a LAN link or Ethernet port is usually a sign that it is operating at 100 Mbps. See page 12 of the manual:
>>>> R7000 | Product | Support | NETGEAR <<<<
It does suggest that you have a connection.
michaelkenward
Aug 11, 2017Guru - Experienced User
