dlbrum's avatar
dlbrum
Connecting ATT netgear 7550 gateway to remote nighthawk bridge router by ethernet
Is it possible to extend my wifi gateway services to a remote building by ethernet connection between a netgear 7550 ATT gateway,  and a remote nighthawk wifi router (in bridge mode ?)  and extend  m...
  • antinode's avatar
    antinode
    Aug 16, 2020
    > [...] using old school connect: [...]
       You can do that, but the router-as-WAP might lose capabilities like
    time server access.  (Does anybody really know what time it is, ...)
       If the router has the feature, then I'd use it, and wait for problems
    to arise.
    > [...] to improve packet transfer speed. [...]
       I'd run the experiment.
       If the router lacks the feature, or if performance is poor, then I'd
    see, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
