Dandrewsca7
Feb 10, 2025Follower
Connecting both Nighthawk devices
How to connect my nighthawk X 10 R 8900 together with my Nighthawk switch S 8000
1 Reply
Check the user manual or quick installation guides for the switch, on how to get the switch connected.
https://www.netgear.com/support/product/gs808e/#docs
You'll need a CAT# LAN cable to connect the switch to the R series router.
