Ianski
Nov 08, 2022Aspirant
connecting expansion hard drive to R7000 - only seeing small partition
I have just purchased an expansion hard drive (Seagate, 8 TB) to replace a 4 TB drive that failed. When I plug this new drive directly into a Windows PC and use Computer Management, I can see that it...
- Nov 08, 2022
I would try and hid the EFI partition on that drive from being seen or that drive needs a full on removal of that partition and re-partitioned so that no EFI partition is seen on that drive.
Nov 08, 2022Guru - Experienced User
Ianski
That's likely the correct path, I will try that. Thank you!
I noticed you responded to a previous thing I posted several months ago. I don't seem to be able to update that one, but the solution for me for that issue (internet dropping every day or so) was to reset the router back to the default settings and re-program it. Hasn't given me any trouble since.
