1169chicken
Jan 06, 2022Follower
Connecting extender to router
I have a Netgear AC1200 WiFi Router, model R6120. I bought a Netgear Wifi Range Extender AC1200, mdl EX6110 Followed instructions for WPS (wtf is that?) for two steps and got stuck/supified. Step...
Jan 06, 2022Guru - Experienced User
If you're struggling with the installation using the WPS setup method, you could always use the installation assistant.
Tends to work better in my opinion.
