edchristopher
Jan 02, 2024Aspirant
Connecting Nighthawk AD7200 to External NAS
I just received my first NAS, a Synology DS224 with the two Ethernet ports that can be aggregated. Not something that I have ever done or really understand. I also have a Nighthawk 9000 with a 10G po...
- Jan 02, 2024
No. The SPF port needs a adapter that converts the SFP port to ethernet connection. The SPF port doesn't support LAG. The SPF port supports LAN side connection of a 1 to 10Gb connection rate or and WAN side connection to a ISP modem or ONT. 1 thru 10Gb connection rate supporting.
There is LAG on ports 1 and 2 on the LAN side so you can connect a LAG supporting device here on these two ports for LAG support. I would presume the NAS that supports LAG here would connect to ports 1 and 2 if you enabled LAG on the R9000 router.
Best to contact the NAS mfr for more help and support information regarding there product and LAG support.
Jan 02, 2024Guru - Experienced User
