cmhoc
Nov 15, 2020Follower
Connecting Non-Wireless printer to RAX45 Router
I have a NON-wireless printer that I would like to use wirelessly via my router. Printer is Brother HL-2240. I currently have it plugged in to the USB port on my RAX45 Nighthawk router. I've instal...
antinode
Nov 15, 2020Guru
> [...] Printer [...] USB port on my RAX45 [...]
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "printer".
I also found nothing. Not all Netgear routers offer the feature you
want.
> [...] I may be able to get a printer to ethernet cord...if it will
> work. [...]
That's usually called a "(USB) print server", and, if it works at
all, then it should work with any router.
