KE_Young's avatar
Dec 21, 2021
Connecting R6850 to WiFi repeater
Model version R6850
Firmware V1.1.0.84_1.0.1
Can the AC2000 connect to a wireless WiFi repeater? I've found instructions on Netgear site regarding an advanced setting: Advanced Setup > Router/AP/Bridge/Repeating Mode but I do not have this option under Advanced Setup. Is there another option for this router?
  • IF Bridge or Repeater modes are not seen then this router doesn't support those features.
  • FURRYe38's avatar
    • KE_Young's avatar
      KE_Young
      Tutor
      It has a VLAN/Bridge settings option but that does not look what I need. Only a check box for "Enable VLAN Tag". I'm not familiar with that but I doubt that's what I need. Thanks.
