hagan91
Dec 08, 2021Initiate
connecting router to mobile wifi
I am trying to determine if it is possible to connect my NetGear Router to my Mobile Wifi hotspot device. I don't have any hardwired internet. the only connectivity is via a Mobile Wifi Puck. how c...
Dec 08, 2021Guru - Experienced User
what version of the R6700 do you have and what firmware is on it?
there's 3 versions of the R6700. Not sure what versions support it but some had an extender mode.
You can check out this thread that goes over setting it up a little bit.
hagan91
Dec 09, 2021Initiate
I have the R6700v3. Thanks for pointing me in the right direction. I will give this a shot and see if it works
