Ahall1113
Jun 14, 2021Aspirant
connecting security camera issues
I have an Arlo 4 Essential and it will find the wifi but not allow the set up. All of the troubleshoot from Arlo has been done and they have determined that it is due to the firewall settings on my r...
Jun 14, 2021Guru - Experienced User
What modem/gateway do you have?
What firmware is on the router?
what actual issue happens during setup? (details help us more than "will not setup"
Ahall1113
it is an Arris 6190 modem, I have the most recent firmware update on the router as of Saturday but I am at work so I cannot access the device currently. The arlo app finds the wifi, has me enter ssid, attempts to set up camera then gives me an error after about 4 minutes. Typical error code is C223 which is a wifi issue. I spent the better part of 3 days on with Arlo as they had me power cycle devices, reinstall app, all of the basic troubleshooting etc. The camera will connect when I use my phone hotspot so it is not a camera issue or arlo app issue. Every one of the 4 level 2 techs I spoke to have said it is an issue with the firewall settings blocking the setup.
