Ahall1113
Jun 14, 2021Aspirant
connecting security camera issues
I have an Arlo 4 Essential and it will find the wifi but not allow the set up. All of the troubleshoot from Arlo has been done and they have determined that it is due to the firewall settings on my r...
Jun 15, 2021Guru - Experienced User
The version I'd recommend is more than 2 versions back. The version prior to netgear armor is 1.0.4.28
Try that version and after installing it, do a factory reset, and then a new install. Don't use a backup configuration.
Ahall1113
Jun 15, 2021Aspirant
I will give that a shot tonight.
