AlexSung's avatar
AlexSung
connecting smart plug(2.4ghz) to CM1200 + Google nest wifi router config.
Hi,
I would like to have my smart plugs connected to new set up but having really hard time find a way to make 2.4ghz enabled.
even I connected to http://192.168.100.1/, it doesn't show options to enable 24ghz.
  • plemans's avatar
    Thats because the CM1200 isn't a router. Its a modem only device.
    It doesn't have router/wifi capability.
    • AlexSung's avatar
      AlexSung
      thank you. does that mean I have to do something with Nest to enable 2.4ghz?
      • plemans's avatar
        Most google routers that I've seen are dual band. (haven't seen a single band one)
        So more than likely, 2.4ghz is already enabled.
        Just make sure your phone is on the 2.4ghz while you're setting up your smart switches.
