Jaxie's avatar
Jaxie
Follower
Jun 28, 2020
Connecting speaker to wifi
I have tried several times to connect a Medion X61002 speaker, md43259, with both wifi and bluetooth to my router/modem to play Sirius XM from my computer.  I have my tvs, computer and phone connect...
  • antinode's avatar
    Jun 28, 2020
    > Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
       Is that accurate?  Not "C7000v2"? Look for "Model" on the product
    label.
    > md43259, with both wifi and bluetooth to my router/modem [...]
       What led you to believe that a C7000[vX] does anything with
    Bluetooth?
    > [...] I can get it to connect to bluetooth, but not wifi. [...]
       You might be able to "get it to connect to" something using
    Bluetooth", but I doubt that the C7000[vX] is involved.
       Regarding a "wifi" connection, "can [...] not" is not a useful
    problem description.  It does not say what you did.  It does not say
    what happened when you did it.  As usual, showing actual actions
    (commands) with their actual results (error messages, LED indicators,
    ...) can be more helpful than vague descriptions or interpretations.
    > [...] put it in the pairing mode, [...]
       Actual "pairing" is a Bluetooth concept, not a Wi-Fi concept.
    > [...] is it not possible to connect a wireless speaker to a computer?
       You should be able to connect a Wi-Fi-capable device to your wireless
    router.  If your (unspecified) "my computer" is also connected to that
    router, then, with appropriate software, your computer and that device
    should be able to communicate with each other.  But Bluetooth would not
    be involved in that connection.
       Bluetooth might be useful to connect the speaker to some program
    source like a smart phone, but that connection ("pairing") would not
    involve the C7000[vX].
