StuckinUtah
Mar 19, 2021Aspirant
Connecting to Cannon MX490 printer
I'm trying to connect my new Netgear AC2600 router to my Cannon MX490 printer using wireless. It previously was set up using LAN settings and a WPS button on the old router. The 2600 router does not have a WPS button. The instructions from the printer say that it can be connected without the WPS button using a PIN number. I got the PIN number from the printer display, but I'm at a loss as to how to input this number into the router. Any suggestions? Thanks.
> I'm trying to connect my new Netgear AC2600 router [...]
That's this?:
> Model: R7450|Nighthawk AC2600 Smart WiFi Router
Look for "Model" on the product label.
> [...] The 2600 router does not have a WPS button. [...]
The R7450 seems to. Visit http://netgear.com/support , put in your
(actual) model number, and look for Documentation. Get the User Manual
(at least). Read. Look for "WPS button with LED". Further reading
might not hurt, either.> [...] I'm at a loss as to how to input this number into the router.
> [...]That's not amazing.
> [...] Any suggestions? [...]You might find some relevant information in a widely neglected
resource:- StuckinUtahAspirant
The model number is AC2600, as I said. Yes, I HAVE READ THE **bleep**ING MANUAL for both the router connection to the printer and the printer directions for connecting to the router. The printer is about 10 years old, which may account for some lack of compatibility between the two. I have never had problems connecting wirelessly to a router. Perhaps you don’t know everything????
It’s really sad that someone who is as angry as you lurks around a site meant to offer help to people. I’m sorry you need your mommy. This isn’t Facebook you freak. Get a life.> The model number is AC2600, as I said. [...]
Sorry. I was misled by this (different model) in your post:
> [...] Yes, I HAVE READ THE **bleep**ING MANUAL [...]
In the AC2600 User Manual, too, I see "WPS button with LED".
> [...] The printer is about 10 years old, which may account for some
> lack of compatibility between the two. [...]It might, if there were some incompatibility. But, so far, there's
no real evidence of that.> [...] Perhaps you don't know everything???? [...]
That's certainly true, but I _can_ find "WPS button with LED" in an
AC2600 User Manual.> [...] Get a life.
Mine's ok. Perhaps you should get a child to help you with your
reading comprehension.
