Philippe2021
Jun 11, 2021Guide
Connecting two linux PCs by ssh
Hello, I have two Ubuntu PCs on my network. I can use ssh from one PC to the other one if they are connected by ethernet to the router. I can't if one of the two PCs is connected by wifi. I r...
Philippe2021
Jun 12, 2021Guide
A _computer_ does not have an IP address; a network _interface_ has an IP address. If a computer has more than one active network interface, then each one must have its own IP address. If you're trying to reach a computer's wireless interface at the IP address of that computer's (disconnected) Ethernet interface, then I'd expect problems.
I pick the IP adress in the Web interface of the router of course.
What, exactly is "<pc2>"
<pc2> is an IP adress. Right now, my laptop computer is on wifi, and my desktop computer always on ethernet, and I have that from my desktop (mars):
XXX@mars:~$ ssh 192.168.1.4 ^C XXX@mars:~$ ping 192.168.1.4 PING 192.168.1.4 (192.168.1.4) 56(84) bytes of data. 64 octets de 192.168.1.4 : icmp_seq=1 ttl=64 temps=198 ms 64 octets de 192.168.1.4 : icmp_seq=2 ttl=64 temps=16.4 ms ^C --- statistiques ping 192.168.1.4 --- 2 paquets transmis, 2 reçus, 0 % paquets perdus, temps 1002 ms rtt min/avg/max/mdev = 16.434/107.459/198.484/91.025 ms
My desktop computer can ping 192.168.1.4 which is my laptop on wifi but not get a ssh connection.
Even a
dmesg
does not give any information, not even a timeout message. The wifi blocks ssh for some reason (the port 22 is blocked maybe for some reason).
Philippe2021
Jun 12, 2021Guide
I can give the logs of the router but that won't help I guess.
[admin login] from source 192.168.1.30, Saturday, June 12, 2021 08:16:44 [DoS Attack: SYN/ACK Scan] from source: 52.162.107.6, port 443, Saturday, June 12, 2021 08:11:20 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:49:19 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:48:39 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:48:39 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:48:39 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:48:28 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:58 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:29 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:14 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:45:28 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:44:53 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:44:53 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:44:53 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:44:27 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:44:27 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:44:27 [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:26 [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:26 [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:25 [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:25 [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:24 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:43:28 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:43:28 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:42:36 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:42:04 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:42:04 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:42:04 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:41:06 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:40:25 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:40:14 [admin login] from source 192.168.1.30, Saturday, June 12, 2021 07:39:21 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:39:16 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:39:15 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:39:15 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:39:15 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:59 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:53 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:38:47 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:38:47 [DHCP IP: 192.168.1.4] to MAC address 9c:b6:d0:8d:a5:3f, Saturday, June 12, 2021 07:38:47 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:38:47 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:38:47 [DHCP IP: 192.168.1.4] to MAC address 9c:b6:d0:8d:a5:3f, Saturday, June 12, 2021 07:38:47 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:16 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:37:46 [admin login] from source 192.168.1.4, Saturday, June 12, 2021 07:36:53 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:36:46 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:36:16 [DumaOS] DHCP new lease allocated., Saturday, June 12, 2021 07:35:44 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:35:44 [DHCP IP: 192.168.1.4] to MAC address 9c:b6:d0:8d:a5:3f, Saturday, June 12, 2021 07:35:44 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:35:20 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:34:46 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:33:38 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:33:38 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:33:38 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:33:12 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:54 [DoS Attack: SYN/ACK Scan] from source: 52.162.107.6, port 443, Saturday, June 12, 2021 07:32:49 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:47 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:22 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:31:42 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:30:42 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:30:12 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:29:38 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:55 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:29 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:13 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:27:25 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:25:55 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:24:34 [DumaOS] DHCP new lease allocated., Saturday, June 12, 2021 07:24:12 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:24:12 [DHCP IP: 192.168.1.11] to MAC address 48:b0:2d:09:8a:35, Saturday, June 12, 2021 07:24:12 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:23:53 [admin login] from source 192.168.1.30, Saturday, June 12, 2021 07:23:51 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:59 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:28 [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:22:25 [DumaOS] DHCP new event., Saturday, June 12, 2021 07:22:25 [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:22:25 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:13 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:21:29 [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:19:59
