lankylad's avatar
lankylad
Connecting Two R7000s Together
I would like to extend my R7000 network into a mesh. If I buy another R7000 will they connect together either via ethernet or WIFI to create a mesh with a single user identification experience?
  • microchip8's avatar
    Feb 22, 2021
    These are not Mesh routers. You can connect them to each others (Access Point), but you won't be able to create a true Mesh network, even if you turn on Smart Connect (which is buggy across many NG routers).
