jrharris
Sep 29, 2020Aspirant
Connecting used router to century link
Just purchased used R7500 router. When installing tells me to go to open wifi networks and connect to my new routers address. The new address does not show up in available wifi. Any suggestions?
- Sep 30, 2020
> I was told [...]
Trust no one, I always say.
antinode
Sep 29, 2020Guru
> Model: R7500|Nighthawk X4 AC2350 Smart WiFi Router
Is that accurate? R7500 or R7500v2? Look for "Model" on the product
label. Firmware version? Connected to what?
> Just purchased used R7500 router. [...]
And did what with it? Which type of CenturyLink service? Is there a
modem involved?
> When installing tells me [...]
"installing"? What, exactly, are you doing? "tells me"? What,
exactly, "tells" you what, exactly, when you do what, exactly?
> [...] connect to my new routers address. [...]
What, exactly, does "my new router[']s address" mean to you?
> [...] Any suggestions?
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read.
When dealing with a used device, a settings reset is usually a good
way to begin. Look in the User Manual for "Factory Settings".
