80roc80
Jun 08, 2021Aspirant
Connecting Xbox wirelessly to c7800
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to ...
- Jun 09, 2021
factory reset on the xbox?
If its just one device having the issue, I'd be looking at that device closer
Jun 08, 2021Guru - Experienced User
Are any other devices having issues?
Or just the xbox?
are you using any special characters/spaces in the ssid/password?
did you "forget" the network on the xbox and reconnect to it?
anything else change in the C7800 since you had it wirelessly connected?
- 80roc80Jun 09, 2021AspirantAll other devices are working and connecting fine, using same passwords /ssid. I have tried everything I can think of besides factory reboot
