80roc80
Jun 08, 2021Aspirant
Connecting Xbox wirelessly to c7800
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to ...
- Jun 09, 2021
factory reset on the xbox?
If its just one device having the issue, I'd be looking at that device closer
Jun 08, 2021Guru - Experienced User
Are any other devices having issues?
Or just the xbox?
are you using any special characters/spaces in the ssid/password?
did you "forget" the network on the xbox and reconnect to it?
anything else change in the C7800 since you had it wirelessly connected?
80roc80
Jun 09, 2021Aspirant
All other devices are working and connecting fine, using same passwords /ssid. I have tried everything I can think of besides factory reboot
- plemansJun 09, 2021Guru - Experienced User
