80roc80's avatar
80roc80
Connecting Xbox wirelessly to c7800
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to ...
  • plemans's avatar
    Jun 09, 2021
    factory reset on the xbox?
    If its just one device having the issue, I'd be looking at that device closer
