80roc80
Jun 08, 2021Aspirant
Connecting Xbox wirelessly to c7800
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to ...
- Jun 09, 2021
factory reset on the xbox?
If its just one device having the issue, I'd be looking at that device closer
ThePodCastGuy
Jun 10, 2021Tutor
Did you notice any latency issues when changing to WiFi? My current router courses lag problems on most games when I change to wifi even though I am close to the router. New router on it's way soon so hopefully might be able to dich the cable
