jwpeak
Apr 08, 2021Tutor
Connectinig new computer
I have purchased a new computer (HP running Windows 10) and want to connect it to my wifi. In trying to connect it asks for the Network Key. Even though I use the key on the bottom of the device, ...
jwpeak
Apr 08, 2021Tutor
Thanks!
jwpeak
Apr 11, 2021Tutor
Okay, hardwired to router from new computer, was able to access internet and also update the router password.
I then removed the cord and tried to connect via the wifi. The message is that there is no internet. Our phones are connected, Alexa is connected, our TV is connected, but not the new computer.
The Internet LED is amber, which I don't believe it has been before. I've restarted to router and then both the router and the modem. The computer still won't connect to the wifi and has the same message that there is no internet.
What now?
- plemansApr 11, 2021Guru - Experienced User
what modem do you have?
Did you go into your computer and forget the network and then try reconnecting it
