Geoff332
Sep 26, 2021Aspirant
Connection Dropping
Hi there, I've been having a problem - and I think I've narrowed it down to my router. Periodically, a bunch of my devices (two Google Home devides, Samsung Tablet, Google Chromecast) start h...
Geoff332
Sep 27, 2021Aspirant
Unfortunately, updating the firmware hasn't fixed the problem. It works for a bit, then some devices get blocked from the internet. The problem seems to be on the 2.4k band - but not all devices on that band. If I reboot the rooter, it works for a while. If I turn off an disconnect an individual device in the Nighthawk app and turn it back on, it seems to start working again; but then gets blocked again.
Sep 28, 2021Guru - Experienced User
After you upgraded the firmware did you do a factory reset and reinstall (not from a backup)?
- Geoff332Sep 30, 2021Aspirant
I did. Same pattern - worked for a bit, then dropped connections and no closer to acutally knowing why.
I'm pretty close to getting rid of it - I need a reliable rooter, not one that regularly drops out half my devices.
- plemansOct 01, 2021Guru - Experienced User
You can try going back to the agreed upon stable 1.0.9.42 that most recommend for the R7000 and try that.
Again, install over a hardwired connection, then do a factory reset/reinstall. disable auto updates and try it.
- Geoff332Oct 01, 2021Aspirant
OK - I'll give that a go. I can't do it over a wired connection, I've not had a ethernet port on a laptop for 5+ years.
Given we're just updating firmware in the hope of fixing things, I'm pretty much done after this - I need reliable hardware and this ain't it. (I know it's not your fault - I'm just very frustrated. I do appreciate your help).
