Henderson
Feb 14, 2017Aspirant
"Connection has been reset" when trying to access router setup pages
When trying to access the router setup pages from my main PC, (Windows 10 64-bit with Anniversary update, wired) all it brings up is "The connection was reset", it won't even bring up the login box. ...
- Feb 14, 2017
First you must reset your router with the reset button on the back pressed in for about 10 seconds until the power light turns orange and starts to blink.
Second Kaspersky has been known to cause this problem. It must be uninstalled and reinstalled in order to get the login to the router back. Not sure about the procedure but searching this forum will show you other peoples solutions to this problem.
