annrpetersen
Mar 15, 2016Aspirant
Connection interrupted and a network change was detected message received on R7000
Upgraded to windows 10 and am now experiencing random interuptions to the connection and receive a message "a network change was detected". sometimes it reloads the page automatically and sometimes ...
- Mar 21, 2016
Do you have another computer to isolate the problem?
If you do, try to use that computer and see if it will show the same thing.
If it does, time to get a new router. Check with support if you're still under warranty for replacement.
ElaineM
Mar 16, 2016NETGEAR Employee Retired
@annpetersen You may need to update the driver of the wireless adapter installed on the computer.
By the way, is it just happening on that particular computer? How about other devices such as mobile phones, laptops, tablets?
