Dunkin4gzus
Jan 10, 2021Tutor
Connection issues with Nighthawk x6 R8000 dropping connections
Just lately my nighthawk x6 will drop connections on wifi devices or at least it says it's still connected, but there is no actual communication. I tried switching to another older wireless router I...
Jan 11, 2021Guru - Experienced User
what modem/gateway do you have?
what actual firmware did you install?
After the install, have you tried a factory reset and a clean install (not using a backup configuration)?
- Dunkin4gzusJan 16, 2021Tutor
It's on firmware V1.0.4.68_10.1.75.
I just tried re-applying the firmware and doing a factory reset. I'll see if it keeps having the issues this week. I'll reply again if it still has issues.
Thanks
