dargelas's avatar
dargelas
connection
ON a R6700v3
Unable to connect to UI of router
I did several resets
Check out the connection wifi to router is on
While ping the router the adress point correctly 192.168.1.1
I did try flushdns command
I did clear all caches
The router works but i can't get the UI with routerlogin.net or routerlogin.com
please could you give me some help?
thanks in advance
1 Reply
  • plemans's avatar
    Do you have it connected to a modem/gateway? and if so, which one?
    Try disconnecting it from your modem/gateway, then factory reset the R7000 (push and hold reset for 7-15 seconds while its powered on), then try access it from the 192.168.1.1
