COUZON
Feb 11, 2022Aspirant
Connections Aircard 790 à une prise connectée dOOwifi
Bonjour
Pour connecter ma prise dOOwifi il faut que je me Connect au wifi 2,4 GHz mais il y a interférence avec le wifi 5 GHz
Comment puis je procéder
Merci
Merci
1 Reply
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with Mobile (L and M series) routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircardOr here:
https://community.netgear.com/t5/Routeurs-et-hotspots-mobiles/bd-p/fr-aircard
Thank you
