Tio1
Aug 05, 2021Aspirant
Connectivity to the router C7800
Yes, where I live I have a dish satellite from AT&T. I would like to find out if the router C7800 is compatible, to connect to the router.
Aug 05, 2021Guru - Experienced User
The C7800 is a coaxial modem device. Its not capable of connecting with dish service.
You could get a router only device and connec to your current gateway. There'd be a few settings to change but it should work.
- Tio1Aug 05, 2021AspirantOk thanks
What about the model C1900 cable modem router it could help me about the connection?
Thank you again.- plemansAug 05, 2021Guru - Experienced User
Not sure what you mean by "It could help me about the connection"?
A coaxial modem connects to coax isp like xfinity/cox/spectrum.
If you've already got a gateway from your dish services then you'd want just a standard router like the R**** series of routers.
here's the series:
CM: coaxial modem only
C****: coaxial modem/router
R****: router only models
RAX: AX routers
D****: DSL modem/router devices
EX: extenders
EAX: AX extenders
- antinodeAug 05, 2021Guru
> The C7800 is a coaxial modem device. [...]
"coaxial" is not the important part. A satellite gizmo might use
coaxial cable, too. What matters is what's at the other end of that
coaxial cable. A Netgear model Cxxxx, CAXxxx, or CMxxxx expects to talk
to a cable-TV ISP, not to some satellite gizmo.
> What about the model C1900 cable modem router [...]Not a Netgear model number.
