Tio1
Aug 05, 2021Aspirant
Connectivity to the router C7800
Yes, where I live I have a dish satellite from AT&T. I would like to find out if the router C7800 is compatible, to connect to the router.
Tio1
Ok thanks
What about the model C1900 cable modem router it could help me about the connection?
Thank you again.
Thank you again.
Aug 05, 2021Guru - Experienced User
Not sure what you mean by "It could help me about the connection"?
A coaxial modem connects to coax isp like xfinity/cox/spectrum.
If you've already got a gateway from your dish services then you'd want just a standard router like the R**** series of routers.
here's the series:
CM: coaxial modem only
C****: coaxial modem/router
R****: router only models
RAX: AX routers
D****: DSL modem/router devices
EX: extenders
EAX: AX extenders
