jjantille
Jan 03, 2022Aspirant
Connexion à un routeur R6220 avec une station météo
Bonjour ! J'essaie de connecter ma station météo (infactory) à mon téléphone Samsung. Les données arrivent correctement sur l'écran de la console météo, mais impossible d'afficher les données sur m...
Jan 03, 2022Guru - Experienced User
What modem/gateway is the router connected to?
What firmware is on the router?
Does it work if your phone is on cellular data and not wifi?
jjantille
Que veut dire :
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole-> ??
- plemansJan 03, 2022Guru - Experienced User
sorry, language barrier.
Current setup: is just what I"m currently using in my home.
The modem/gateway is what the router connects to. What gateway is the R6220 connected to?
- jjantilleJan 03, 2022Aspirant
Thank you for your answer ! Nice !
My gateway is : 192.168.10.1
that's its IP address. What model gateway is it? (look at the label)
you might have better luck in the french version
https://community.netgear.com/t5/NETGEAR-Forum/ct-p/fr-netgear
