Jetster
Dec 30, 2021Follower
connext usb printer to extender ex8000.
Widows 10 router r8300 extender ex8000 latest firmware
Dec 30, 2021Guru - Experienced User
You gave us nothing to go off.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Netgear has set up a community forum specifically for the Wireless Adapter products. Most of the people who watch that forum are more likely to have experience with wireless adapter products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Adapters/bd-p/home-wifi-adapters
Thank you.
