codymeche1972
Mar 06, 2024Aspirant
connnecting 2 netgear routers together
So i have my main router, a R7900P, i just bought an AX1800 router. I have run a cat5 from the main wireless router to my office outside the house (well within the distance cable of doing so) when i ...
- Mar 07, 2024I got it fixed. Basically 1 wireless route connected to another via ethernet. Both routers just set up right out the box normally, each a stand alone independent wifi's. So I am thinking it was a firmware issue on the older 7900
I took both rax10's and set each up in the sake fashion updating the firmware and everything came right back up
microchip8
Mar 06, 2024Master
Which router model? AX1800 is a speed, not model!
You should only have one router doing the routing in your network. Put this "AX1800" router in access point mode
codymeche1972
Sorry RAX10
