codymeche1972
Mar 06, 2024Aspirant
connnecting 2 netgear routers together
So i have my main router, a R7900P, i just bought an AX1800 router. I have run a cat5 from the main wireless router to my office outside the house (well within the distance cable of doing so) when i ...
- Mar 07, 2024I got it fixed. Basically 1 wireless route connected to another via ethernet. Both routers just set up right out the box normally, each a stand alone independent wifi's. So I am thinking it was a firmware issue on the older 7900
I took both rax10's and set each up in the sake fashion updating the firmware and everything came right back up
michaelkenward
Mar 07, 2024Guru - Experienced User
codymeche1972 wrote:
So the modem is in an enclosure mounted to the outside of my house by the ISP. Ethernet comes from directly to the 7900 router. It's was in there before I built the office.
Without knowing more, it is hard to diagnose what might be going on.
I'm still finding it hard to work out what you are doing.
Take this:
Both were just set up standard and have been running fine for years until 2 days ago.
What do you mean by "set up standard"?
Two routers?
Does the R7900P connect to the Internet?
Then this:
Switched ports at the 7900 also and still nothing.
Switched ports?
Switched what to what?
Troubleshooting is a painstaking process that work up the chain a step at a time, with a clear explanation of what is going on.
You also haven't answered various questions on the way that could help us to understand what is going on. But let's not muddy the issue any more. Start by telling is what goes on at the R7900P.
codymeche1972
Mar 07, 2024Aspirant
