dptraynor
Jan 04, 2021Tutor
Constant Disconnects - Netgear R6400 v2 - Router Mode - .71, .75, .80
Hello! I have experienced an issue with my Netgear R6400 (v2) in Router Mode. It works on reboot for a few minutes. Then it disconnects and the Nighthawk app reports it as offline if I check there...
dptraynor
Jan 04, 2021Tutor
It does not. Once I notice the disconnect, I perform a reboot, and it works again for a short time.
Jan 04, 2021Guru - Experienced User
What modem/gateway is the router connected to?
- dptraynorJan 04, 2021Tutor
It's plugged directly into a wall outlet. Our apartment building has managed internet service with a provider called SingleDigits.
I'm not sure how to check the details of the gateway. But if it's something I can pull from the router admin page or my command prompt window then I will check it.When other devices such as video game consoles or PCs are plugged into the wall outlet, they work just fine. They also work when connected to the ISP's wifi. But for security reasons I'd rather route them through this router.
