yagirlchels
May 06, 2021Aspirant
CONSTANT DOS ATTACKS & DISCONNECTION
[ Spoiler ] For the last two weeks, my internet has been acting up and keeps just randomly disconnecting. Only for a couple of seconds but it happens back to back all day long. Can someone help me u...
carapungo
Nov 04, 2021Aspirant
were you able to fix this issue?, what was causing it, and what was the solution?
- microchip8Nov 04, 2021Master
NETGEAR is famously known for many false positives DoS attacks. Their "protection" is virtually useless. I suggest turnning off DoS protection completely off and see if you get a stable device. Myself, I've been running without DoS protection since I bought my router (3.5 years ago) and never had an issue.
- carapungoNov 04, 2021Aspirant
Thanks. That's what I did this morning, and now my event log is empty, which I assume is a good thing. I have not seen any connection drops so far.
- FURRYe38Nov 04, 2021Guru - Experienced User
What NG product do you have?
- yagirlchelsNov 05, 2021Aspirant
So, I actually had to contact my ISP (xfinity) and end up getting an entirely new IP address for my router. Nothing else was working. I havent had an issue since then.
- FURRYe38Nov 05, 2021Guru - Experienced User
Sounds like this was coming in from the ISP side then.
Please mark your thread as solved so others will know.
Enjoy.
