bm22
Dec 17, 2020Aspirant
Constant Errors Only with NBA 2K21
I get disconnected from every NBA2K21 online game I try to play. I keep getting the same error codes despite not losing connection to the internet. I have 1GB internet and am connected to the router ...
bm22
Dec 23, 2020Aspirant
I just tried that and didn't get the error.
Dec 23, 2020Guru - Experienced User
try this. install version 1.1.0.86 of the firmware to it. Make sure to do it over a hardwired connection. Once installed, factory reset the router and do a clean install (not from a backup). Disable auto-updates.
Once reinstalled, put the consoles IP address into the netgears dmz again.
run it. see how it works.
- bm22Dec 23, 2020Aspirant
Ok. Can you clarify the DMZ part? I'm only seeing "Default DMZ server" as a DMZ option. So just make sure that's checked and enter the console's IP into it? My console's IP address isn't the one entered for it currently, could that be a potential fix?
- plemansDec 23, 2020Guru - Experienced User
