bm22
Dec 17, 2020Aspirant
Constant Errors Only with NBA 2K21
I get disconnected from every NBA2K21 online game I try to play. I keep getting the same error codes despite not losing connection to the internet. I have 1GB internet and am connected to the router ...
bm22
Dec 23, 2020Aspirant
Ok. Can you clarify the DMZ part? I'm only seeing "Default DMZ server" as a DMZ option. So just make sure that's checked and enter the console's IP into it? My console's IP address isn't the one entered for it currently, could that be a potential fix?
Dec 23, 2020Guru - Experienced User
